87 Warrior
Old Jan 14, 2009 | 05:26 PM
DrewJones87's Avatar
Default 87 Warrior
i like my 87 warrior but i want a clear answer to this question i would like to be able to pull up wheelies without having to stand on the grab bar what size front sprocket do i need to do that. would be awesome if i could get this answered.
Old Jan 14, 2009 | 05:53 PM
mechanicock's Avatar
Default 87 Warrior
dude it can be done, on my 88 before it was rebuilt then ultimatley stolen, i could wheelie without standing on the grab bar. You have to dump the clutch like a mo fo to get it up. What you have to understand is the motor in you warrior is placed farther toward the front of your frame makin it harder for you bike's front end to raise up.
Old Jan 14, 2009 | 10:26 PM
Raptor450's Avatar
Default 87 Warrior
Stock is 13 teeth, so a 12 tooth would help. But no matter what you do, a Warrior is not a good wheelie machine, but it can be done with the right technique without standing on the wheelie bar. Just be careful and wear a helmet! For the machine to go straight, the rear tire air pressure has be be even and you can steer it slightly by leaning right or left. If it feels like it is going back too far, LIGHTLY tap the back brake and it will bring the front end down. If you drag the wheelie bar, just hold on to the bars and hug the tank with your knees and lightly tap the back brake to get it off of the wheelie bar. If someone gave me this advice years ago, it would've saved me a few trips to the emergency room.
Old Jan 14, 2009 | 10:36 PM
Default 87 Warrior
i know how to ride a wheelie. ok so thats why the front feels so freakin heavy. check out this website you can widen you atv with out having to pay 500-1000 dollars this is what im goin to do with my next paycheck. http://diamondjcustoms.com/new/index.htm
Old Jan 14, 2009 | 10:42 PM
laxattack99's Avatar
Default 87 Warrior
I have a 87 warrior to. Before i got my pipe it was tough to get the front end up. I did it without popping thrle the clutch . I just dumped the gas and leaned back. With the pipe its a whole lot easier so im sure its possible u just have to practice alot. Hope i helped
Old Jan 14, 2009 | 10:46 PM
Raptor450's Avatar
Default 87 Warrior
<div class="FTQUOTE"><begin quote>Originally posted by: DrewJones87
i know how to ride a wheelie. ok so thats why the front feels so freakin heavy. check out this website you can widen you atv with out having to pay 500-1000 dollars this is what im goin to do with my next paycheck. http://diamondjcustoms.com/new/index.htm</end quote></div>
I hate to say this, but that kit is junk. I have heard some bad stories about those kits.
Old Jan 14, 2009 | 11:45 PM
Default 87 Warrior
ok i will try that and it would help if i lowered my psi in my tires, and a 12tooth sprocket wouldnt hurt would it
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
