o1 660 raptor cuts out at high rpm
Old 01-17-2009, 11:11 AM
raptor25's Avatar
Default o1 660 raptor cuts out at high rpm
hi, i had this same problem with my 05 raptor 660. I cleaned the air filter, put new gas, and changed the oil. Now it runs just fine. So i dont no mabey this will help.
Old 01-17-2009, 02:20 PM
extremelawncare's Avatar
thanks will try that first , checked on new rev box this morning it is a little over 400.00 so we will try other things first .
Old 01-19-2009, 12:38 AM
sluckman's Avatar
So you rebuilt the carbs? Did you check your float bowl heights? Check your main jet sizes, and or needle height. Take air filter off for a short run, and see if that helps, if so your main jet may be too rich. Check spark plugs, wet and black too rich. Should be light brown (like toast).
Hope this helps.
Old 01-19-2009, 12:46 PM
thanks
Firefighter400
10-08-2022 06:38 PM
GNorm
08-01-2015 11:06 AM
black_thunder
07-26-2015 09:23 PM
black_thunder
07-22-2015 06:01 PM
Dirtbikemike1
07-11-2015 03:36 PM
Quick Reply: o1 660 raptor cuts out at high rpm
