rear shock leak
Old Jan 21, 2009 | 05:47 PM
87 warrior's Avatar
Default rear shock leak
my 87 warrior's rear shock appears to be leaking fluid after a day of riding. there's a puddle on the floor of my shed right under the shock and is about the size of a music CD. the rear doesn't lift when you pick the rear up so the shock can't be bad....? it does squat quite a bit with me on it though. i weigh 160 so i dunno if that's normal or not....? any help would be great
Old Jan 26, 2009 | 07:24 PM
workin_hard247's Avatar
Find a local shop that repairs atv/sled shocks. They are cheaper than you might think to repair.
Old Jan 26, 2009 | 07:33 PM
87 warrior's Avatar
do you have a ballpark range of how much it would cost?
Old Jan 26, 2009 | 07:58 PM
I am not an expert on shock repair, but it sounds like a seal is leaking. Shocks need rebuilding after awhile. I would suggest explain your situation to a repair shop and see if they can give you a price range. Depending on where you live, there are places that specialize in shock repair. You might have better luck with them.
if I had to GUESS... under $50 (if you remove the shock yourself).
Don't ride the bike w/o fluid in the shock, you will do more damage to it.
Good luck!
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
Sandman2.0
Jul 21, 2015 09:03 AM
cSchwartz
Jul 9, 2015 02:40 PM
