Yfz 450r top speed?
Old Feb 28, 2009 | 09:48 PM
ITP Racing's Avatar
Default Yfz 450r top speed?
What is the top speed of a yfz 450 and any suggestions on how to make it faster with out puting your life savings into it
Old Mar 1, 2009 | 12:41 AM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
a $20 sprocket will increase top speed, more teeth on the front makes it have more top end speed, and so does a less tooth rear sprocket.
Old Mar 1, 2009 | 04:46 AM
91Warrior357's Avatar
i think yfz do about 76 or so i believe and gearing is the cheapest way to change speed, it doesnt add any actualy power it just shifts it around.
Old Mar 1, 2009 | 09:11 PM
Jojo-YFZ-ESR's Avatar
retard the cam if it isnt, that will give you more top end for free, and a 15 tooth front gear. If the cam hasnt been turned, its very simple, go to yfz central and they show u step by step
Old Feb 23, 2013 | 03:41 AM
Spacemuis@'s Avatar
Stuff done on my R
Cams
Ported
Racing intake filter
Pro circuit full system
Front sprocket 15
It does 87.5 mph on the GPS on tarmac....
Old Feb 23, 2013 | 02:50 PM
Scooter86's Avatar
Knows Old ATV Questions!
Low to mid 70's stock top speed. What do you mean by "faster?" Gearing like said above will buy you a little top speed, but acceleration will suffer. An aftermarket slip on and an intake plus rejetting/fule tuner wakes them up pretty good.
Old Apr 4, 2013 | 09:18 PM
2001YamahaShee's Avatar
70-80mph
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
