1997 Banshee Engine trouble
Old Mar 13, 2009 | 06:37 PM
surferguy7's Avatar
Default 1997 Banshee Engine trouble
Banshee bogs down when I hit power band. I have cleaned the carbs and the bike still continues to bog when I hit power band. It runs fine when idling. Any ideas or suggestions
Old Mar 13, 2009 | 08:34 PM
surferguy7's Avatar
Bump
Old Mar 14, 2009 | 01:43 PM
surferguy7's Avatar
bump
Old Mar 14, 2009 | 04:23 PM
murox's Avatar
Have u done any mods like pipes that would require to rejet that you haven't mentioned? Go into more detail and I'd expect more responses.
Old Mar 14, 2009 | 04:42 PM
surferguy7's Avatar
The bike has Toomy t5's and is jetted correctly! I cleaned the carbs and air cleaner. Any ideas?
Old Mar 14, 2009 | 05:09 PM
95wolv's Avatar
Did it run fine previously and now started to bog, or after the Toomeys and rejetting? If it was good then started to act up, you could check your reeds, or make sure both your carbs are opening together, I know on a sled, if you have one carb that lags the other, it will run like crap when you try to open it up.
Old Mar 14, 2009 | 05:15 PM
surferguy7's Avatar
I took the bike to get the pipes put on and the guy put the wrong jets in which screwed up the motor. He rebuilt the motor and and put the right jets in. Ran fine for a couple trips then starting screwing up. Cleaned carbs and checked jets, everything is good. But still bogs down when I hit it.
Old Mar 14, 2009 | 11:20 PM
91Warrior357's Avatar
its prolly still something in your carb, whats the plugs look like, and do the pipes smoke evenly? also after running for a bit see if pipes are about the same temperature.
Old Mar 14, 2009 | 11:56 PM
JLsparky7's Avatar
If he jetted it wrong it probably was lean and it scored the walls of the cylinders. He probably just threw new rings on it when gave it back to you. The cylinders need to be honed.
Old Mar 15, 2009 | 12:09 AM
surferguy7's Avatar
Good point. I will check that tomorrow! Today I took the bearing out of the gas cap, which could possibly be a problem. Started the bike, warmed it up, and it hit power band no problem. But I will look at the cylinders tomorrow. Thanks for the info!!!!
Matt
Cole Hadden
Jun 15, 2025 09:05 AM
ltrmc02
Jul 22, 2015 04:50 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
