2003 blaster promblem
i trade for it and it has fmf exhaust and i cleaned the carb.i fixed the tors system and it has good compession .i also cleaned the air filter and checked the reeds.my promblem is it has a miss or sputtering and it dont seem to have as much power as it should.they just overhauled the motor but it has a loud noise in the top of it would this cause my promblem .i forgot to add it has a 230 main jet i dont no if this is the right size or not.it seems like the rev limiter is kicking in lower rpms.any help is appreciated thanks.
Make sure and take the carb completely apart, so many don't take the main nozzle out and this will create a bog and sputter from mid range up. Like JLsparky7 asked, I don't know where your located but 230 seems small. Granted we had a lot of work done to the motor but we ran a 330 or 350 main. But just make sure you take ALL the pieces apart to clean it.
I live in TN and 230 is fine for a stock blaster but you might need to go up to a 260 or even a 280 with the pipe. Clean the carb and check your plug gap and coil for resistance.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
