warrior gears are too low
Old Mar 25, 2009 | 07:16 PM
canoeman43's Avatar
Default warrior gears are too low
i rebuilt an 88 warrior and man that thing is geared low,i changed the primary gear to a 10,the rear is 40 and its still pretty low.how small a sprocket can you get for the rear?also i need a set of GOOD rear tires if anybody has a good source.
Old Mar 25, 2009 | 07:25 PM
91Warrior357's Avatar
bigger the front sprocket larger the gear ratio, smaller the rear sprocket larger the gear ratio, i use a 13 which is stock i believe, for warriors i like kenda klaws, maxxis razrs, and itp mudlites those are prolly my favorite tires for warriors
Old Mar 26, 2009 | 03:26 AM
beefy46172's Avatar
Loves To Ride!
Well yeah with it being a 10 that is ridiculously low. The smaller you go on the front the lower the gearing goes. 13 front/40 rear is stock for a Warrior.
Old Mar 26, 2009 | 08:43 AM
wilson8305's Avatar
yeah the smaller you go on front, the slower and more power you have, the bigger the faster and less power
Old Mar 26, 2009 | 09:39 AM
95wolv's Avatar
The Warrior has enough low end grunt to pull a one tooth bigger up front, I know a lot of guys who run a 14 up front for better gear spread, and a little more top end speed.
Old Mar 26, 2009 | 10:03 AM
wilson8305's Avatar
yeah my brother n law had a 95 warrior a couple years back and he put 14 in front and i can't remember what in back, but riden after that it actually seemed like a whole different machine, buti guess that was a while ago, but sprockets can make a big difference, let out some a that hidden power i mean
Old Mar 27, 2009 | 08:25 PM
trail hound 97warrior's Avatar
14t front 40t rear with 20in tiers is a perfect combo. made plenty of gear and less rotating mass i love it. but thats just me.
Old Jun 9, 2009 | 09:27 AM
KYDRIVER_1's Avatar
Not to thread jack but I was looking into getting some 20-11-9's for the back and 22 or 21-7-10's for the front and going to a 14 tooth front sprocket is that a good set up on a warrior. I climb a lot of hills and do a lot of trail riding. Thanks guys.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
