fuel requirements
Old Apr 8, 2009 | 10:05 PM
Tag75's Avatar
Default fuel requirements
I have recently purchased a 2005 raptor 660r. I did not get any book/manuals with it.
Can I run 87 octane gas or do I need High octane.
Old Apr 8, 2009 | 10:09 PM
91Warrior357's Avatar
your fine with 87 you dont have to run any higher unless its a high compression engine.
Old Apr 8, 2009 | 11:29 PM
Tag75's Avatar
As far asI know the engine is stock. That is the problem though. I dont know how high they have on a 660r stock. I have seen that some stock ATVs need 92.
Old Apr 9, 2009 | 12:52 AM
bigned1904's Avatar
whats the elevation where u ride?
Old Apr 9, 2009 | 12:58 AM
Tag75's Avatar
I mainly ride around eastern IL and at the Badlands offroad park in Attica In. I dont know the elevation. Not very high I would guess.
Old Apr 9, 2009 | 01:15 AM
to be honest i always use 93 or so for the hell of it, specially if two stroke, my warrior requires 93.
id use 93 anyway, but i dont think stock raptor 660s have that high of compression.
Old Apr 9, 2009 | 08:11 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
I know the 450 stock needs high octane. My yfz will make a ting'n sound from the engine if I run anything below 91. I'm not sure with the 660 but, I figured it would require 91. Call a dealer and ask what Yamaha recommends.
Old Apr 9, 2009 | 08:18 AM
bigned1904's Avatar
with lower elevation i would use good gas. its not that much more $
Old Apr 9, 2009 | 08:42 AM
TLC's Avatar
TLC
Makes sense,since the 450s have the same high compression motors that are in the high strung go or blow motocross bikes.
The 660 on the other hand has a motor derived from Yamaha,s XT660 on/off commuting motorcycle which run regular gas.
Old Apr 9, 2009 | 09:01 AM
Koopa's Avatar
I did not know that. If that's the case it most likely does fine on 87.
If you want a positive answer, call a dealership and ask. I know sometimes they would put a sticker on the vehicle if it required anything over 87. Our old 2-stroke GP760 waverunner had a badge stating 91 octane. Anyone know if they did this on quads? (I have aftermarket plastics.)
Most large bore quads are lower compression engines. With that it mind combined with what TLC said. I'd say 87 is fine.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
PrairieDog126
Sep 12, 2015 06:53 PM
MrTrashMan2U
Sep 9, 2015 11:11 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
