Help with Blaster
Old Apr 10, 2009 | 08:59 PM
kyleag89's Avatar
Default Help with Blaster
Ok well I just bought a 95 I believe Blaster. It runs great sometimes, and then out of no where it looses spark. It will only give spark once and a awhile and will run for about 2 minutes then die. I know the coil is good because I swapped it with a known good one.
Old Apr 10, 2009 | 09:24 PM
boudro13's Avatar
try testing out the stator, a manual should have the readings u need to test to see if it's good
Old Apr 10, 2009 | 09:35 PM
kyleag89's Avatar
A stator would cause intermediate problems?
Old Apr 10, 2009 | 10:37 PM
91Warrior357's Avatar
sounds like corroded or frayed wires somewhere, maybe the killswitch, if its not a faulty coil or stator.
Old Apr 11, 2009 | 10:08 AM
kyleag89's Avatar
Is there a way to disconnect the kill switch to rule that out?
Old Apr 11, 2009 | 07:22 PM
j carey's Avatar
all you need to do is just unplug the kill switch,that should tell you if it is the kill switch or not.what i have done on all my blasters is to put a extra ground wire from the motor to frame,where the gas tank bolts down,it never herts to have a extra ground
Old Apr 11, 2009 | 09:01 PM
kyleag89's Avatar
Well after looking at a wiring diagram I decided to hook up the cdi but leave the black/white wire disconnected. The black/white wire feeds the switch, carb unit, throttle unit, and control unit. If I leave this disconnected it runs.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
