help!!!yamaha blaster case bearings
Old Apr 11, 2009 | 10:51 PM
b_s_chance's Avatar
Default help!!!yamaha blaster case bearings
so i am building a big bore,stroked,blaster..want to replace all bearings in the compression and trans chambers in the case...i have a normal captive bearing puller(three jaws with a expanshion screw to go in the inner bore of the bearing)so the damn catches on the end of the jaws are too thick to get under a few of the blind hole bearings...any sudgestions????????????also a good place to order all bearings from????have to be c3 grade' with the high compression hemi head and turbo blue race fuel and all.thanks
Old Apr 12, 2009 | 03:04 PM
JLsparky7's Avatar
Find a socket the same size as the inside of the bearing and hammer it out with the socket on the bearing.
Old Apr 13, 2009 | 12:16 PM
b_s_chance's Avatar
a blind hole is one that has a bottom in it...cant push the bearing thru that way.has to be pulled from the in side through the center bore. only has about 1/16 on an inch between bearing and inside of the case.;.just not sure what to use
Ean
Dec 19, 2022 08:48 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
Peter_
Jul 18, 2015 07:06 AM
ghost civic
Jul 15, 2015 10:48 PM
joeyupton
Jul 14, 2015 11:51 AM
