New brake pads on warrior?
Old Apr 13, 2009 | 06:02 PM
Toyota Dave's Avatar
Originally Posted by Chris82
Looks like we have the same troubles, i have yet to get mine on i have thought about taking the hole brakr apart lol
Same here. Im sure someone knows why? A Picture should help.
As you can see the space in between the pads is anough for the rotor to fit but that one part is taking up some of the space?
Old Apr 13, 2009 | 08:34 PM
free2blaze's Avatar
that plate with the rubber pieces on it should move back also, I believe you just push it back, on mine there is a metal piece inside those rubber boots, I believe that plate is ment to move in as the prake pads wear
Old Apr 13, 2009 | 08:39 PM
I have tired that but it does not seem to want to move. I only see one screw to turn.
brake2.jpg?t=1239674183
Old Apr 14, 2009 | 05:49 AM
beefy46172's Avatar
Loves To Ride!
I will say mine always had to be forced on prior to removing my park brake assembly. Ever since then they go on with ease.
Old Apr 14, 2009 | 09:55 AM
  #15
I still have yet to get it on most of the bolts are rusted or have striped heads on them. Is there a aftermarket one?
Old Apr 14, 2009 | 06:56 PM
  #16
racerex1's Avatar
My parking brake adjuster would not move and I could not get the caliper to expand enough to install new pads, so I purcahsed a block-off plate and just removed the entire parking brake set-up (including the cable, etc). The block-off plate was dirt cheap. Once I had the parking brake removed, the new pads were installed in seconds. IMO, the parking brake is a total waste.
Old Apr 14, 2009 | 07:11 PM
  #17
Im starting to think the guy gave me the wrong pads they are EBC FA84X
Old Apr 14, 2009 | 07:43 PM
  #18
beefy46172's Avatar
Loves To Ride!
Those are the right pads. Most likely your park brake assembly is FUBAR and needs removed/blocked off. They serve no good purpose and tend to just cause brake drag anyway.
Old Apr 14, 2009 | 07:51 PM
  #19
I have the parking brake completely removed but i do not have a block off plate yet would that make any differance?
Old Apr 18, 2009 | 07:33 AM
  #20
I bought a brand new brake caliber and it went on fine.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
