Valve Adjustment
Old Apr 15, 2009 | 07:52 PM
webbl19's Avatar
Default Valve Adjustment
Ok so i want to check my valves on my 89 warrior not sure when the last time it has been done, and i just got it 3 weeks or a month ago, i have never done it before, im familier with car engines but not small engines.
I stopped and got a feeler gauge just now so i can check the gap. And in the service manuel it says a valve adjustment tool? Do i need this or can i just use a wrench?
Also do you need to take off all that stuff just to get to the valve? (gas tank and such)
Any tips and tricks would be awesome.
Thanks
Old Apr 15, 2009 | 08:06 PM
webbl19's Avatar
never mind the gas tank question i just went out and looked at it and you have to take it off.
Old Apr 15, 2009 | 08:15 PM
91Warrior357's Avatar
yea you just gotta pull the gas tank off the two valve covers, cam cover, and stator window plug, and the plastic cover on the stator cover to turn the bolt with a wrench, then get it at TDC, you will just need a feeler gauge and a wrench for the nut and a wrench for the valve adjuster so you can hold it still while you tighten the nut after you make an adjustment, just make sure after you tighten it up real good to measure it again and make sure its still within spec, i think i usually use needle nose vise grips to hold the adjuster still while i tighten the nut.
Old Apr 15, 2009 | 08:22 PM
webbl19's Avatar
ok where it the cam cover? is that the round black cover at the top and where is the plastic cover you are talking about? i think i know where the plug is.
Old Apr 15, 2009 | 08:31 PM
cam cover is the round cover left side of engine it has 2 bolts, and the plastic cover is the one that says yamaha on it left side also, it just covers a bolt, and you turn that bolt to get your engine to TDC
Old Apr 15, 2009 | 08:36 PM
webbl19's Avatar
the plastic one you are talking is about, is it the cover that holds the pull start?
Old Apr 15, 2009 | 10:52 PM
webbl19's Avatar
ok i figured it out, mine is not plastic, it is aluminum or something.
anyways checked the valves they were with in specs.
thanks for the help
Old Apr 16, 2009 | 06:58 AM
thanks for the help
oh whoopsies forgot your was an 89, yea pullstart lol, good deal though.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
