Banshee Rear Shock Seal Replacement??
Old Apr 21, 2009 | 08:44 AM
Sport400inOH's Avatar
Default Banshee Rear Shock Seal Replacement??
I've got the new seal head in hand, but can't seem to get the shock to come apart.
Is there a trick or secret to getting it apart? Do the rebound setting need to be at a certain point or ??
There isn't anything in my repair manual...but I need to get this done as my seal went bad and all of my oil leaked out.
Old Apr 21, 2009 | 09:27 AM
What I need to know - Is there a trick or special method to removing the dust cap?
Old Apr 22, 2009 | 08:08 PM
Anybody?
Old Apr 24, 2009 | 07:29 AM
Raptor450's Avatar
I'm having the same problem trying to get someone to rebuild my Tri-Z shock, which is almost the same as a Warrior shock, and similar to a Banshee shock. I was going to rebuild it myself, but could not find ANY info on how to do it. So I took the shock to a suspension shop, and even they couldn't get it apart! This shop usually sets up dirtbike motocross suspensions, though. I ended up taking it to my Yamaha dealer, and they got it apart, but they will not rebuild it. I did find a guy that will rebuild it if I ship it to him, his cost is $130 for new seals, new oil, and recharged with nitrogen. I'm sure he could dod a Banshee shock. Do you have the tool to re-charge it with nitrogen after you put it back together? I did find the tool for $220, and I use nitrogen for work, so that was not a problem.
Old Apr 28, 2009 | 09:55 AM
I found a site with some instructions on how to get it apart. The dust cap is just a press fit, then the seal head is held in by a circlip. Once you have it apart, you can remove the bottom mounting portion and remove the seal head. I got a replacement sealhead from Rocky Mountain ATV for just over $30. The Oil was another $12 and I have a local MC/ATV shop than will charge it for a few bucks. I should have under $60-75 in the rebuild. I just need the time to work on it.
Old Apr 30, 2009 | 11:54 AM
Got the new Seal head in. My local ATV dealer is going to charge me $5 to fill it with Nitrogen. These shocks have a special self-sealing rubber plug. The dealer inserts a special needle (Like the ones that you use for injecting grease in a sealed ball joint) and inflates it through there.
So my updated cost is about $50 with tax on everything. What a deal!
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mikea1978
Jul 4, 2015 12:37 PM
