04 YFZ450 seems to be running hot. Is that normal?
Old May 11, 2009 | 10:05 PM
Nightwatch's Avatar
Default 04 YFZ450 seems to be running hot. Is that normal?
I just finished changing plug, oil and flushing radiator. I'm a little confused because the manual says the capacity of the cooling system is 1.3L (.29 is in reservoir) but I couldn't get the full 1.0L in the radiator. I buttoned it up and started it and after about 5 minutes idling I shut it down and everything was very hot.
Is the high temp normal? The fan didn't kick on. I could barely touch the hose.
Should I be able to get the full 1.0L into the system after it get's through motor?
At what temp does the the fan kick on?
Thanks...
Old May 11, 2009 | 11:14 PM
JLsparky7's Avatar
The air has to work its way out of the coolant system. It will take a few rides.
Or you could pruge the system which is when you purposly overheat the bike a little to force the air out.
Keep your res full and the air will work its way out.
Old May 12, 2009 | 07:04 AM
Nightwatch's Avatar
thanks JLsparky7
Old May 13, 2009 | 06:26 AM
tfunk22008's Avatar
the yfzs run very hot its nothing to be worried about my 06 and 09 both run real hot. if i turn the lights off in my garage and start my bike in a minute or two the header will glow cherry red both of my quads did that right from factory its just how they are made
3quadbob
Sep 18, 2016 09:46 PM
NLWarrior01
Jun 28, 2015 12:54 PM
Specwar
Jun 27, 2015 08:59 PM
VRRRRT
Jun 20, 2015 03:47 PM
vernl
Jan 7, 2001 08:13 PM
