2000 warrior timing issue
Old May 26, 2009 | 06:22 PM
K-Man's Avatar
Exclamation 2000 warrior timing issue
Just rebuilt the top end on a 2000 350 warrior because of a valve issue.Got it back together and now it will only idle,sounds great till you hit the throttle then it just bogs and back fires. I've set the timing a dozen times and even rebuilt the carb. I'm not an ace mechanic by any means by I can handle the basics. I set the timing marks at top dead on the fly wheel, set the cam at the mark on the head with the piston up,valves are set. Am I missing something or is there something I did wrong? Can anybody offer any advice.
Old May 26, 2009 | 06:30 PM
91Warrior357's Avatar
whats the details of this valve issue? it could be multiple things even the parking brake sensor can cause a problem like that.
Old May 26, 2009 | 06:33 PM
K-Man's Avatar
The rocker lock nut backed off and damaged the rocker,so I had another head rebuilt and installed it
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
jag6510
Jun 15, 2015 05:59 PM
wbfjim
Jun 8, 2015 06:20 PM
soccermike7
Oct 5, 2000 08:21 PM
