need help with valve timing 1989 yfm 250 moto-4
Old Feb 21, 2025 | 11:28 AM
  #21
Nate490's Avatar
Originally Posted by 91Warrior357
it kinda is a big job,you gotta set the timing to TDC then you gotta take the head off to get the tensioners and chain out, and youll need a new head gasket and side cover gasket since you gotta pull those off, your problem might not even be the timing, it could just need the carb cleaned out.
You don't actually have to remove the head it makes it easier and cheaper not removing the head you will have to remove the side cover and you can remove the tensioner and guide through the bottom
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Unzzy66
Jul 11, 2015 10:01 PM
Mojave250A
Jul 11, 2015 10:38 AM
