2001 Wolverine Clutch
Old Jun 30, 2009 | 10:20 PM
mud99's Avatar
Default 2001 Wolverine Clutch
How hard is it to put a new clutch or clutch pack in a Wolverine 4X4. I need to replace mine.
Old Jul 1, 2009 | 07:54 AM
Kevin R.'s Avatar
Isn't that a auto model?
Old Jul 1, 2009 | 11:10 AM
mud99's Avatar
I think its called an automatic clutch. It has gears, its kinda like the honda fourtrax , foreman, ect
Old Jul 1, 2009 | 12:20 PM
95wolv's Avatar
It's pretty easy, just buy a gasket for the right side (as you sit on it) engine case, drain the oil, get a piece of cardboard and put the bolts for the cover in it, some are different lengths, and need to go back in the same spot to work ! The clutch pack is just like a manual one, just pull the bolts, remove the old plates, install the new, best thing is to have a manual, and when you drain the oil, soak the new plates in it, they work better installed 'wet'.If you are handy with a wrench at all, it should only take you 2 hours tops, if you are very handy, you could have it done in 45 mins to an hour. Then stop beating on it!!! I still have the stock plates in my 95 Wolverine, and I rode the living pi$$ out of it !! Just kidding, ride the hell out of it and have fun.
Old Jul 13, 2009 | 09:51 PM
mud99's Avatar
well put the clutch in and it was easer than i thought. Now with that said watch it start leaking or something lol.
Minimod
Sep 10, 2015 09:20 PM
chewy78
Sep 8, 2015 10:37 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
cdstang
Aug 31, 2015 07:52 AM
