Blaster troubles
Old Aug 6, 2009 | 11:23 AM
blasterman831's Avatar
Angry Blaster troubles
Just took my 01 blaster to the dealer could nt get it to run right. Just put new carb on replaced both gaskets up and lower. Just got a call from the dealer and they said "the bike has no compression" but when i took the motor a part to replace gaskets the piston and rings were fine. Could there be a crack in the head i just don t see thats causing this. Need some help im loosing my mind
Old Aug 6, 2009 | 09:12 PM
Terrellster's Avatar
Either you're a mech or not..... If not, you're doomed to deal with what they throw at you at the Stealership.
If you're a mech. Take it home and figure it out. Buy a (whatever name brand you can find) manual, and start learning. If it had compression when you dropped it off, it probably still does.
"Not running right", is a vague description of your troubles, but I bet you could figure it out anyway..... be brave. Tackle it yourself. You'll be surprised how well you'll do. (and buy a torque wrench if you don't already have one....)
Old Aug 8, 2009 | 06:18 PM
rschaub's Avatar
Default Blaster not running right ?
Not a lot of help from that last reply. There is a manual on line...http://www.rydindirty.com/blastermanual.pdf. Take a look. Explain what you meant by not running right. You might need a new plug ? You wasted your money on a new carb..should have just cleaned it out. If it ran it had compression. Might be a charge coil...look in the manual for the specs. Could be a broken reed ? Could be a lot of things. Tell us what doesn't run right mean...good luck.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
nastyblaster100
Sep 13, 2015 01:19 PM
