96 warrior 350
Old Aug 21, 2009 | 05:34 PM
Vistal's Avatar
Default 96 warrior 350
Hi all my question is a.bout the base gasket on the 350 and how hard is it to change.I do work on a lot of cars and have a small leak on the left rear o.f the jug
Old Aug 21, 2009 | 08:48 PM
Malachi's Avatar
Might as well buy a top end gasket set. You'll be lucky to get the other parts off without ruining the old gaskets.
Should be an easy job if you've got mechanical ability and decent tools. Might be a good time to freshen it up while your at it.
Just don't let the timing chain fall into the case. It can be a bear to get back up and on the lower gear.
Old Aug 22, 2009 | 12:20 AM
Vistal's Avatar
So is it pretty simple as just taking the head bolts off then the exhaust and sliding it up?Im buying a manual tomorrow and i bought the gaskets already. I was going to have a guy do it on the side but he seemed to be a scamer wanting me to bring it to his house and leaving it over night. He said it take 5-6 hrs but the Yamaha shop said 1-2 hrs MAx. Its so simple to steal a atv. In most states all you need to do is claim its custom and remove all serial # and give em a good paint job with custom plastic and the state will give ya a custom title. I learned this form a douche down the road which i then Had busted and got a few grand in rewards).
Old Aug 22, 2009 | 12:45 AM
Malachi's Avatar
Yeah, it's pretty straight forward. I'm not sure about the 350 but usually take the cam cover off, remove cam gear, then pop the head off, then cylinder all the while keeping some tension on the chain.
Be a good idea to do the valve seals too while you have it apart. A cheapy valve spring compressor will get the valves free.
Just make sure timing is still correct after you get the tensioner back in place. May take a couple trys to get it right.
Old Aug 22, 2009 | 09:19 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
it's easily a 5-6 hour job.. especially if you've never done it before. but don't jsut take it to a random guys house
Old Aug 27, 2009 | 09:17 AM
Swerve's Avatar
Yea it takes a little while just to get all the crap out of your way to get to it but over all it's pretty straight forward especially if you have ever replace the head gasket on something else. Like everyone said though don't drop the timing chain down in the engine.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
