98 Grizzly Floods When Gets Hot
Old Aug 30, 2009 | 02:56 PM
boggyvfd's Avatar
Default 98 Grizzly Floods When Gets Hot
I have a 98 Grizzly 600, I have completely gutted and replaced everything in the carb. It runs fine for about 20 or 30 minutes but after it gets hot it starts flooding. The overflow tube has a constant drip of gas coming out when it's hot. If I let it cool for about 30 minutes and crank it, it runs fine again. I don't understand what the problem is. Any ideas?
Old Aug 30, 2009 | 06:55 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
stuck float or worn out needle seat. strange though.. boiling gas maybe?
Old Aug 31, 2009 | 08:17 AM
boggyvfd's Avatar
Yeah, I thought it might be something with the float but it's all new float, needle, gaskets, etc. Someone told me it might be vapor lock which I guess is what you are referring to about boiling gas. If that is the problem, what is the solution? Some kind of heat shield around the carb?
Old Aug 31, 2009 | 09:46 PM
cadillacdude1975's Avatar
have you checked the choke to see if that is operating properly?
Old Aug 31, 2009 | 10:39 PM
IdahoVinnie's Avatar
At a minimum, it sounds like your float is adjusted a bit too high, causing flooding, and dripping out the overflow.
Old Sep 6, 2009 | 09:50 PM
boggyvfd's Avatar
Yeah, I thought the float needed adjustment, but it doesn't flood or run out the overflow until it gets hot (after running at least 20 to 30 minutes). I'm absolutely confused. I guess I'm gonna have to take it to the dealer and let them charge me and arm and a leg to figure it out, ha.
Customer Service #1
May 15, 2020 08:46 AM
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Jaymc
Sep 11, 2015 07:45 AM
