98 grizzle 600 carb. help
Old Sep 16, 2009 | 09:39 PM
mowermanga's Avatar
Default 98 grizzle 600 carb. help
I just bought a 98 grizzle 600, the only thing wrong is that when the gas is on, gas runs out of the overflow on the bottom of the carb. Is there something I can do to stop this?
Old Sep 17, 2009 | 08:58 AM
02magnum500's Avatar
Gets his share of deer.
Check your needle and seat in the carb. and make sure it is shutting off the fuel when the float rises up. Check the float level as well. If the rubber part on the needle is bad fuel will just run into the carb and go out the overflow on the bottom like you describe.
Old Sep 25, 2009 | 09:38 PM
mowermanga's Avatar
Just now getting some time to work on the 4wheeler. Should I start with replacing the float and the needle and then go form there? Is there an adjustment for the float level?
wendal
Oct 31, 2017 03:31 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
