Running lean?
Old Sep 18, 2009 | 08:26 AM
Tallerico250's Avatar
Default Running lean?
Hey everyone, what I would like to know is if the symptoms my bike is experiencing is due to the carb running lean. It usually takes a good 3-5 mins of cranking to get it to start cold and another couple minutes with the choke on or hit the throttle to stay idle. I have a 06 250 Bruin with stock Mikuni 33mm carb. Could I adjust the carb to make it run richer? once it's warmed up it runs fine.
Old Sep 18, 2009 | 08:53 AM
Stoopidbot's Avatar
What elevation are you at?
Old Sep 18, 2009 | 09:01 AM
I live in Missouri, it's pretty low, not sure on exact feet though
Old Sep 18, 2009 | 09:31 AM
ss97's Avatar
Lets Ride!
One sign of a lean condition is an overheated engine. If its running a bit too hot you might see a glowing red head pipe.
Another sign is a backfire during engine braking or deceleration.
If everything is stock and its running lean, you may have a leak in your air box, or on the intake somewhere before the carb.
The cold starting problem might not have anything to do with a lean condition. Especially a slight lean condition.
Old Sep 18, 2009 | 07:54 PM
Ok I inspected the bike and found a slit in the hose that connects from the air box to the carb. I'll try to replace this and see if it runs better.
Frisky2050
Apr 9, 2020 11:19 AM
marioi911
Sport Quads
Jun 30, 2015 12:00 PM
Mphillips
Jun 26, 2015 03:52 PM
hoopduerr
Jun 10, 2015 03:00 PM
dano00
8
Dec 27, 2000 10:10 PM
