Warrior 350 2001
Old Sep 27, 2009 | 03:54 PM
yamahadriver13's Avatar
Default Warrior 350 2001
Hey guys, My warrior was sitting for only a week or so and when i went to start it, it was smoking bad for about 5-10sec and stoped it wasnt smoking when i put it away so how could that be any ideas?
Mods are only a white brothers exhaust
Old Oct 10, 2009 | 10:12 AM
mthrshp's Avatar
What color was the smoke? It could be your air/fuel mix screw. Dose it still do it after it warms up?
Old Oct 10, 2009 | 10:21 AM
95wolv's Avatar
smoke after sitting a while that goes away quickly is usually the valve guide seals leaking by, you won't see any smoke while running or warmed up, but a few drops get by when it sits for extended periods, then burns on start up, puff of smoke, when the oil is gone, the smoke is gone. It will run like this for a very long time, just looks bad when you first start it. Don't worry about it unless the smoke stays for a long time, that could point to other problems. Just run it for now, you could fix it, but it would involve pulling the head to do it, unless you know a way to pull the springs without removing the head.
Old Oct 24, 2009 | 02:54 PM
dupont's Avatar
i had the same problem with my 2003 warrior. some oil had dripped on the exhaust pipe and burnt off
Old Oct 24, 2009 | 05:00 PM
95wolv's Avatar
That's a good point, dupont, he should definately look at that as well, but I would think it would take more than 5-10 sec. to burn oil off a pipe, plus the smoke would come from the front, not out the muffler.
Old Oct 24, 2009 | 05:40 PM
dupont's Avatar
it would come from the front but on mine it only smoked for 10 seconds
Old Oct 28, 2009 | 08:33 PM
wheily's Avatar
maybe it was like mine of corse it sat a lot longer( stupid rats nest)
Old Nov 2, 2009 | 11:26 AM
Juniorc1717's Avatar
Does anyone know if a yzf450 bumper will fit on a 2002 warrior?
Old Nov 2, 2009 | 11:28 AM
Does anyone know if it is possible to put turbo on a 2002 yamaha warrior?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
