okay then, if you insist it is'nt a bad valve you've got one of 4 problems: 1 your ignition module is burned up 2 you've got a short somewhere in the wiring 3 you did'nt install the coil right (or it's a bad one) 4 the motor is ****ed, your stator is'nt turning
What your describing sounds like a stator issue I had. You need to ohm out the connections on the stator to see if your getting the right resistance on the stator and pickup coil.
