Help Changing Balljoint - 07 350 Grizzly
Old Oct 1, 2009 | 04:37 PM
Xplorer96's Avatar
Default Help Changing Balljoint - 07 350 Grizzly
hey all, i need to replace the left lower balljoint on my grizzly. i bought the balljoint, but the manual says i need a balljoint removal and replacement tool....anyway to change them with out special tools? will a those Forks work? that u use on regualr auto balljoint? thanks alot!
Old Oct 3, 2009 | 09:22 AM
Xplorer96's Avatar
anyone?
Old Oct 3, 2009 | 10:40 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
take a picture of what it looks like(from both sides) on the arm and post it in your pictures.. i've never seen one in person but i will help you out
Old Oct 3, 2009 | 10:44 AM
Xplorer96's Avatar
ok ill go do that now, appreciate it!
iv never changed a ball joint before, even on a car b/c on my truck you replace the whole arm lol....
but i just dont wanna take it to the dealer, dont have that kinda money right now.
i removed everything! hub nut, brake caliper, and the snap ring on the top of the ball joint
Old Oct 3, 2009 | 10:46 AM
Speedy2222's Avatar
if it's like the older warrior arms, it was a snap ring and then the balljoint threaded out. look at the new balljoint and look for threads or if it's "slick" on the sides.. take a picture of the new balljoint too while you have the camera out.
Old Oct 3, 2009 | 10:47 AM
Xplorer96's Avatar
its not threded, ill take a pic of the new one too. i have to use my camera on my phone so they might not turn out the greatest lol
Old Oct 3, 2009 | 11:35 AM
Xplorer96's Avatar
i messed with it till 1am last night, before i came in i sprayed it really good with wd40.
Old Oct 3, 2009 | 11:37 AM
Xplorer96's Avatar
i tried putting a bottle jack between the upper and lower A Arms but it wouldnt fit. i figure if i can get the old on out, i can put the new one in and seat it by just put the nut on the bottom and keep tightening it. idk.... open to suggestions lol
Old Oct 3, 2009 | 11:49 AM
Speedy2222's Avatar
hit the side of the arm where the balljoint tapers in.. this should loosen the taper.. then thread on the castle nut till it is almost flush with the end of the threads and then hit it with a hammer. should pop it loose. the ball joint will need pressed out and the new one pressed in.
Old Oct 3, 2009 | 12:04 PM
Xplorer96's Avatar
ok ill go try that, a vice will work for pressing it right?
