Who has old rear brake cable set up to sell for 98 Blaster??
Old Oct 3, 2009 | 10:33 AM
87warriorpgh's Avatar
Default Who has old rear brake cable set up to sell for 98 Blaster??
Hi, I am looking to buy a original set up, now I have a hydraulic set up from a unknown machine, they just say cp on them. Yamaha could not match the brake pads with anything.
Old Oct 3, 2009 | 10:38 AM
95wolv's Avatar
If it was homemade, it could be a brake assembly off a street bike,look into that before you remove the whole system. Hydraulic brakes are a lot better than the old mechanical brakes that came stock. And don't just limit your search to Yamaha brands, I saw one set up on a Blaster where a guy used the caliper and pads off a Honda street bike,he made a bracket to bolt it on in place of the old mech. one.
Old Oct 3, 2009 | 05:02 PM
Terrellster's Avatar
I thought CP was a performance company that made stuff like that. Turns out it's a marine performance focused co.
I think you will be disappointed with cable operated stuff. A lot of local autoparts places are starting to carry ATV brake pads and shoes. Might try to get someone at the locals to see about matching up for you.
If you still have the original 98 model Brake rotor and all, you could go the cable brake set-up pretty easily. The factory Brakes had the floating disc, the Hydraulics on ater models, the disc is fixed. The axel is different, the hub carrier is different, all kinds of stuff. If you bought yours already modified, you may be in for some pretty heavy research before replacement or up/downgrade.
Old Oct 3, 2009 | 09:07 PM
I just purchased a new rear hydraulic set up fo $50.00, from just for scooters.com.
Quick LinksShipping Options | Return Policy | Questions? Heavy duty rear hydraulic brake kit for dirt bikes and ATVs.Specifications
  • Sleeve length: 14.5 inches
  • Includes: Slave caliper, brake line, brake caliper and pads
Supported ModelsVarious unlisted makes/models Part Number: 110-37 Old Part Number: BRK-6 Price: $44.99 Out of stock
Re-supply date: Early October
Old Oct 3, 2009 | 10:02 PM
95wolv's Avatar
That's a clean looking unit, does it use common ATV type brake pads?
Old Oct 4, 2009 | 02:19 AM
B250Xrider's Avatar
let me know if that dont work I have a nice 88 blaster I am having electrical issues w/. The front and rear brakes are actually perfect. The whole thing is about to get parted out. thanks
Old Oct 4, 2009 | 07:58 AM
Yes, this unit comes with pads, when I receive the brakes Ill give a update how good they are. B250-Im missing the rear bar behind the seat. If you have one I wonder if it would fit?
Old Oct 4, 2009 | 10:12 PM
B250Xrider's Avatar
I dont even have the grab bar on this unit either.
toonces
Oct 16, 2019 12:11 PM
greg74
Sep 10, 2019 03:03 PM
GregM
Mar 6, 2018 06:53 AM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
