Idle mixture adjustment on an '03 660 Grizzly
The idle air screw adjustment is located at the bottom of the carburetor flat blade screw driver. This is what I do start and warm engine till fan comes on then turn flat blade till engine starts to drop in RPM then turn out till Rpm drop again then correct setting is in the middle. Most air screw adjustments are done this way except pros use a tach. Make sure your idle is set to correct RPM then make your adjustment.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
