Electrical problems-03 Wolverine 4x4
Old Oct 14, 2009 | 11:00 AM
ncgator's Avatar
Default Electrical problems-03 Wolverine 4x4
I've browsed topics, none seem to fit my problem.
Recently came into possession of this machine. No electrical functions at all.
No lights on the steering column with key on. I first replaced the battery, as the old one would not take a charge.
I can jump across the solenoid and the starter cranks the engine, but engine does not start. I pulled the plug and grounded it while cranking. No spark. No voltage to the coil with key on. I am new to the cdi, so am not sure if these tests are valid for coming to any conclusions.
Would my first step be to replace the solenoid? Does the cdi take power from the solenoid? Neither of the two small wires on the solenoid show any voltage. Are they just connected to the start switch to activate the solenoid?
You can see that I need some help. Any suggestions will be most welcome.
Thanks,
ncgator
Old Oct 16, 2009 | 05:03 PM
kawicowboy's Avatar
Did you check the fuse by the battery. Its a place to start
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
