Kodiak Freewheeling down hills
Old Oct 23, 2009 | 03:11 PM
Black Kingquad's Avatar
From: I currently live in North central AR ,but am originally from Southwest Pennsylvania.
Default Kodiak Freewheeling down hills
I have a 2000 Kodiak 4x4 and the transmission freewheels when going down hills sometimes.If I bring the idle up just a little, the engine braking works again.A little info about the quad:it has about 3500 miles on it with the original belt,has had water in it before(not a whole lot but some),and has been rolled once by my sister.I took it apart last night and it has a bunch of black stuff (doesn't look like motor oil)everywhere on the pulleys,but the belt seems ok and tight.Could it be the sprag or a worn belt?The engine oil definitely needs changed too.Any inputs are appreciated.-Paul
Old Oct 24, 2009 | 12:16 PM
Nobody?
Old Oct 25, 2009 | 08:01 AM
dupont's Avatar
definitely change the oil regardless of the other problems
Old Oct 25, 2009 | 08:30 AM
TLC's Avatar
TLC
When water gets on a belt it caused the pulleys to go dark Grey almost black with a oily look, from rubber residue. Nothing a cleaning will not cure but after 3000 miles change the belt anyways. Here is a good cleaning the clutches link. Nyroc's ATV info website
Just skip to the 5th paragraph to the cleaning part.
Old Oct 25, 2009 | 04:54 PM
Thanks for the replies and link.
dannytas
Sep 26, 2017 06:31 PM
YankeeRebel
Oct 6, 2015 06:44 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
