1989 Warrior will not rev all the way out
Old Nov 17, 2009 | 10:21 PM
dgilfillen's Avatar
Default 1989 Warrior will not rev all the way out
Hello,
I just recently bought a 1989 Warrior. Please read all the items below as I have had several unrelated problems, and I am trying to figure the final problem out!
First couple of hours riding were OK.
Then, the quad would cut out with just a little bit of throttle. I SOLVED this, and fixed it by disabling the parking brake.
After this, the quad started knocking something fierce. Also, the engine would not rev completely out. It revved MUCH higher than with the parking brake problem, but it lost power at high rpm's I just figured it was noisy valves!
Well, last night, I decided to check the valve clearance. Intake valve had a MAJOR issue: the locknut for the valve tappet came off! I found the nut down in the head, but it did not look like it did any damage. I corrected the clearance this evening, and loctite-ed the threads so it will not happen again.
However... I still have some sputtering and very high rev's. Anyone have any idea what it could be?
Tomorrow night is dedicated to cleaning the carb, so maybe that will fix it.
I appreciate any ideas!
Thanks,
dgilfillen
Old Dec 10, 2009 | 09:28 PM
timwarrior18950's Avatar
Default running bad warrior1
line the timing marks per manual. fly wheel keys are weak on warriors fly wheel only needs to move a little bit on crank to run bad! happend to both of my warriors one was worse than the other. hope this helps!
Old Sep 8, 2011 | 11:51 AM
bryan350's Avatar
well mine wont rev all the way out and it dont have a parking brake on it now it was like that when i got it
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
