1989 warrior specs
Old Nov 20, 2009 | 07:48 PM
jvb's Avatar
jvb
Default 1989 warrior specs
Have a 1989 Warrior, hasn't been used in 4 years, got it running ok, but need to know weight and type of oil for oil change and how much it holds, and type and size of spark plug. Any other usefull info on servicing it. Thanks alot, John
PS did the basics, flushed carb, changes air cleaner, lubed chain etc.
Old Nov 21, 2009 | 06:14 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Welcome to ATV connection John. Since your machine is about 20 years old I would just look around online or at a dealership and pick up a Clymer service manual for it, that will help you with pretty much anything you would ever need to know about your quad. They cost anywhere from $20-$30 bucks but they are a very useful resource.
Old Nov 21, 2009 | 09:01 PM
jvb's Avatar
jvb
thanks
Old Nov 22, 2009 | 11:23 AM
beefy46172's Avatar
Loves To Ride!
10W40 Motorcycle Oil ** Must be wet clutch safe, it it doesn't say it is on the quart don't use it.
Holds 2.78 quarts with filter change, 2.5 without filter change.
NGK D8EA spark plug
Just hit the grease zerks on the front suspension and rear suspension on a regular basis, keep the chain adjusted properly, check the valves every 2*3 months, and give it hell.
Old Nov 23, 2009 | 01:32 AM
B250Xrider's Avatar
http://www.sandwizards.com/Service_Manuals/warrior.pdf
to hell with the clymer...
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
raman8tor
Sep 20, 2015 07:35 AM
