Blaster Piston Size 125??
Old Nov 28, 2009 | 07:48 AM
Facinus's Avatar
Default Blaster Piston Size 125??
So I'm doing a top end rebuild and the blaster I have has been bored out so I'm not sure of the piston size. The piston has 125 stamped on top. Which makes no sense to me in inches, mm, or anywhere on the web can I find what size this correlates to. Any ideas?
Old Nov 28, 2009 | 10:47 AM
b_s_chance's Avatar
Smile
stock displacement on a blaster is 196cc(they say 200)but actual is 196cc its stamped on the left side of the jug.the stock bore is equal to 66mm. so the piston u have i am assuming is .125 over but i would measure in with an inside micrometers. before u order a new piston.make sure u hone or have some one hone the cylinder to brake the glaze.
Old Nov 28, 2009 | 09:21 PM
Terrellster's Avatar
could it be the weight of the piston?
Old Nov 29, 2009 | 12:32 AM
b_s_chance's Avatar
no..i have been working on bikes for a long time and have never seen the piston weight scribed on it...99.9% sure that it is meaning that it is .125 over bore.if you have like a harbor freight or northern tool.(cheep tool stores sells knock off and reman tools) get your self a cheap set of calipers and measure the i.d. of the cylinder.
2many2ride
Sep 27, 2015 04:35 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
nastyblaster100
Sep 13, 2015 01:19 PM
