Warrior 350 rear axle bearing replacment
Old Jan 6, 2010 | 01:32 PM
blackjet84's Avatar
Angry Warrior 350 rear axle bearing replacment
so i messed my bearings up and took apart my rear axle and in order to get the axle out of the hub/bearing spacer i had to hook it up to my truck and the other end to a pole. so that worked and i replaced the bearings and put it back together but how do i get the axle back into the bearingspacer/ hub.
Old Jan 6, 2010 | 07:44 PM
NewportHillClimber's Avatar
you may have to wire brush the crap out of the axle and grease it. they are a very tight fit
Old Jan 6, 2010 | 08:14 PM
Sisco1957's Avatar
Do as NewportHillClimber said. I use a piece of pipe that will fit over the axle splines and catch the shoulder(flair) to remove and install the axle. Tap the pipe with a hammer. It isn't the professional way but works for a poor-boy.
Old Jan 18, 2010 | 01:49 PM
blackjet84's Avatar
so i got it fixed, i wire brushed the hell out of it and then put the bearing spacer after the bearing, in order then i used a cresant wrench and put it on the sides then pounded the hell out of it and it worked a long pipe would have been better but didnt have one. thx for the info guys.
mvwhite
CAN-AM (BRP) Ask an Expert!
Feb 26, 2020 08:54 AM
buckshit
Sep 24, 2015 08:49 PM
Rooky
10
Jun 23, 2015 09:35 PM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 1, 2015 08:22 PM
