warrior HP?
Old Feb 25, 2001 | 08:35 PM
yamahagye's Avatar
does anyone know how many HP a stock warrior has?
Thank You
Old Feb 25, 2001 | 09:52 PM
86atc250r's Avatar
About 17 at the rear tires.
Old Feb 26, 2001 | 03:08 AM
AdrenalinFreak's Avatar
I think It should be somewhere in the low 30's ?
Old Feb 26, 2001 | 03:34 AM
250r89's Avatar
17s way off Gabe. It puts out at least 23 at the rear wheels stock. The 300ex puts out more HP than 17 and the Warrior puts out 7 or 8 more then the ex. Get your facts straight before you post
Old Feb 26, 2001 | 05:23 AM
Loofer's Avatar
Damn..that was harsh
Old Feb 26, 2001 | 09:37 PM
dawarriorman's Avatar
actually everybody is wrong. While im sitting here looking at a dyno run from White Bros. where they compare their pipe to a stock warrior, the stock warrior puts out just over 20 horsepower. And, by the way, a stock 300ex puts out 16 horse, so the warrior is only 4 horse more.
Old Feb 27, 2001 | 02:25 AM
86atc250r's Avatar
Get my facts straight, eh?.
Where you getting your info? SOTP Dyno? Guessing?....
I have cross-referenced about every one of his runs against those found in many different places. His runs are right on. Check them out for yourself, compare against Dynojet & others if you care to.
Of course, throw in a little for differences in bikes, humidities, fuel, altitude, temps, dyno operators, etc... but I think you get the point.
Further verifying the above graph, the 300EX and Warrior are very comparable in the drag race. A Warrior stands no chance against a 400EX with the throttle set properly & equal riders (nor does a 300EX). A 400EX develops approx 26-27 at the rear tires.
Adrenalinefreak - Low 30's? The Raptor barely musters 36-37.....
The Warrior's 2 valve head is a significant limiting factor in it's top end which is where peak HP comes from. It's a torquey engine in a very mild state of tune. 17-18 is a very reasonable number.
Old Feb 27, 2001 | 03:45 AM
The warrior should put out about 30hp at the motor.. I dunno what the rear tires are at. 17Hp is pretty low though, considering that the bike is capable of travelling at 60mph (or there abouts) 17hp at the tires isnt enough to make 500+lbs (bike and rider) go that speed.
Old Feb 27, 2001 | 08:22 AM
WhatRULookinAt's Avatar
On a DYNO Chart I saw, a stock Warrior had 18 HP , rear wheels.
Old Feb 27, 2001 | 03:35 PM
spooge's Avatar
18 stock
