warrior HP?
Old Feb 27, 2001 | 05:30 PM
sAyIt_fmf's Avatar
Yepper.....right around 20 is correct for the warrior.
Old Feb 27, 2001 | 08:25 PM
dawarriorman's Avatar
no, its not 18, its 20. I am sitting here looking at the dyno run. do you want to look at it too?
Old Mar 1, 2001 | 06:04 PM
warriorrules's Avatar
why are you guys bickering. someone says it is 20 and then someone says it is 18 and then someone says no it isn't it is 20. All dynos read differently and don't put out the same exact number.
Old Mar 2, 2001 | 08:45 AM
AdrenalinFreak's Avatar
Not only do all dyno's read differently, But all stock bikes will have slightly different horespower to them. It would be very difficult to create exactly the same bike everytime. The only real way to determine the horsepower is to find the top speed and calculate it from there. There are alot of different equations to do this. Here is one for on level ground, Just to give you an idea of what I mean -
HPs = (MPH ÷ 3) + (WEIGHT ÷ 1,000 x MPH ÷ 10)
Note: assumes engine HP must be 2 x the HP required at drive wheels
So a warrior with a 165 lbs rider @ 60mph would require...
Hp=(60mph/3) + (400lbs+165lbs / 1000x 60mph /10) = 23.3
This statment says that 23.3 hp are required to move 565lbs at 60mph nothing else.But since I dont feel like doing all the math to figure it out exactly, this is all your getting
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
