WARRIOR 350 help
Old Jan 20, 2010 | 04:15 AM
scotthaydt's Avatar
Default WARRIOR 350 help
i have a 1996 yamaha warrior 350 that i bought from a guy who said it needed carb. tuned and air filter bc it had a K&N mass flow intake on it is it true that u have to adjust carb in order for it to run and if so how much of a adjustment should i make and will it run without the air filter im gonna buy one if it runs but im just saying would i need one to just start it
Old Jan 20, 2010 | 02:50 PM
yellowdemon23's Avatar
no it doesn't have to have a filter on it to start. It will probably suck more air then it is supposed to, and not run properly. But you shouldn't ride it without a filter anyways cause you don't want to suck dirt in the motor.
Old Jan 21, 2010 | 09:04 AM
Swerve's Avatar
Sometimes my warrior won't start cold without the air filter. I don't know if it just gets to much air or it needs some back pressure but I was even using starter fluid and it wouldn't start until I set the air filter on it. Also, are there any other mods like exhaust. The carb should have new jets if it is running a K&N filter and exhaust.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
