2002 Yamaha Warrior starting problem
Old Jan 20, 2010 | 05:56 PM
JasonAnderson's Avatar
Default 2002 Yamaha Warrior starting problem
The rubber intake manifold broke so i just got it back from the dealer today and it hasn't been started in about 4 weeks. i tried to start it before i brought it in and it wouldn't start so i figured it was the rubber intake manifold. I put new 91 octane in it and it still won't fire, i took off the spark plug and the spark plug has no spark, all the lights work so i know it's not the battery or anything, and it turns over pretty good, but idk what's wrong with it. Does it need a new spark plug? The spark plug was really wet and black so it could be that. Any help would be good! Thanks!!
Old Jan 21, 2010 | 01:21 PM
warrior-435's Avatar
stick a spark plug out of anything or even a screw driver in the cap to see if your getting fire if not its probaly the pick up coil warrior are bad for pickup coil first thing is go buy a service manual it will be your best friend it tells you how to test every thing and the specs they should be hope this helps
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Nelson
Jun 20, 2015 01:59 PM
1000gade
May 27, 2015 12:37 PM
zuki
Mar 17, 2000 06:04 PM
dunc_n
Aug 26, 1999 09:32 PM
