Warrior not starting... Help!
Old Jan 24, 2010 | 11:36 PM
WarriorRider0277's Avatar
Default Warrior not starting... Help!
Ok, so I just got my warrior back from the shop. It was rebuilt, with new piston and rings, gaskets, valves, a new starter and starter clutch, and a couple of other things including a carb rebuild. Yesterday when i went to pick it up it started fine, but this morning I tried to start but it wouldnt. I tried the choke, starter fluid, but still nothing. Finally I bump started it and it ran. I rode for a while, cut it off, and it started fine. Later tonight after it cooled down, it did the same as in the morning. Please someone help me figure out what this is. Any help greatly appreciated. Oh yeah, I did correctly break the engine in.
Old Jan 25, 2010 | 09:33 AM
Swerve's Avatar
My guess would be to check all your grounds and make sure they have good connection.
That was a good day of riding then. You are suppose to run it at less than half throttle with easy gear shifts for at least ten hours to break in a rebuilt engine.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
