Blaster reving. help
Old Feb 5, 2010 | 09:31 AM
HOOKblaster's Avatar
Default Blaster reving. help
Hey guys im new to the website. I Just cleaned up a 98' blaster that hasn't ran in a few years. new spark plug, pulled the carburetor cleaned it out real good and fresh gas. Took a while but finally got it started. wasn't 5 minutes and it started revving out of control. When i tried shutting it off neither the kill switch or the key stopped it. Had to put it in gear and stall it out. We pulled the air filter off to check if the slide was getting hung up. It started reving again and the slide was all the way down. I read something about pre ignition when the pistons get so hot it doesnt need spark which would explain y we couldnt shut it off... but that's usually after a bike has been warmed up. this happened in less then 5 minutes. Any experience with this? if so your thoughts or advice is greatly appreciated...thanks
Old Feb 5, 2010 | 01:23 PM
Shawn33's Avatar
have you checked you throttle cable.mine did it when the spring in the top carb.got hung up allowing the needle slide to stay open.i would check that area out.
Old Feb 5, 2010 | 06:59 PM
foolish-913's Avatar
high reving is a sign of a possible air leak get some carb cleaner an spray around the head gasket area an base gasket if it revs up when you spray it it has an air leak an new gaskets would probably fix it but if you get no change in the idle speed then i would check the tors on the top of the carb they cause some frustrating problems if you cut an splice the wires to the tors unit it will disable it
Old Feb 7, 2010 | 11:45 AM
2strokezilla's Avatar
foolish is right an air leak between cyl and carb will do that or the tors system will also do it its best to get rid of the tors they sell a kit to remove
Old Feb 7, 2010 | 12:25 PM
the tors kit is nice but is unnescessary just cut the wire an twist them together an its no longer active but the idle **** will still work the problem i have with the kit is you have to drill an tap a hole in your carb to put in a new idle screw
Old Feb 7, 2010 | 05:39 PM
true put the kit in my daughters blaster
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
