Ok some more Newb questions
Old Feb 5, 2010 | 12:36 PM
Cherokee Steve's Avatar
Default Ok some more Newb questions
OK got a couple more questions, my 4wheeler is an 02 kodiak 400
ok so
1) My lights dont work, they worked fine when i got the thing except one bulb was burnt out, changed that, all was good until i put a new winch on. now i have noe lights and i cant figure out why. everything tested out ok.
2) I went to put new brake pads on the rear and noticed the pads were so worn down it wore the piston down on the caliper. So i call the local ATV wrecking yard and they told me to bring the old caliper in so they could match it up. So i unbolt the brakeline and head out. TOTALLY FORGOT TO PLUG THE LINE!!! so i get home and try bleeding the new caliper. Something is wrong. i cant get it to bleed up. The left hand lever and the foot pedal are connected to something down near the front right tire. how do i bleed that thing?
3) I got a smokin deal on a set of 27" Gator tires. these things are amazing. Had to do a little bit of trimming on the rear but they fit great now. So i was wondering what can be done to get a little bit more power out of this machine without breaking the bank.
Any help with any of these questions would be great, thanx
Old Feb 5, 2010 | 02:26 PM
Dirtyone55's Avatar
ok so
1) Electrical problems are a PITA... Be as patient as possible. First step, get you a multimeter, unplug your lights and see if you have voltage to the wiring harness before your lights. I was having problems on my Sportsman and the lights, I inspected the bulbs, and they looked good, so I was thinking the problem was somewhere else, but I tested the voltage and I had plenty, so I just replaced the bulbs and they worked fine. Weird thing was they both went out at the same time.
2) Have you tried a vacuum bleeder? Even a cheapo from HF will probably do what you need it to do.
Old Feb 5, 2010 | 08:30 PM
dupont's Avatar
sorry for not answering you question but I have my own question for you. does you kodiak have differential locks? if so is it good? i have a 1998 kodiak 400 with no diff lock (limited-slip-diff) it sucks it gets stuck all of the time in domb places. I am interested in getting a newer one. any in fo would be greatly appreaciated
Old Feb 5, 2010 | 08:58 PM
no mine doesnt have the difflock either, dont quote me on this but i beleive the difflock came out in 03 on the kodiaks. you can buy lockers for these atvs tho. just do a google search for kodiak locker.
Old Feb 5, 2010 | 09:52 PM
dupont's Avatar
Does yours get stuck alot? when i say mine gets stuck alot i mean ALOT like 4 times every time I ride it
Old Feb 5, 2010 | 09:55 PM
ive only had it since the beginning of december so ive only had it out in the snow. i had half bald 25" kenda bear claws on it and got stuck twice, both were my own stupidity. since i put these gators on i havent had a problem, it will go anywhere i want it to. are you sure your 4wd is working?
Old Feb 5, 2010 | 10:05 PM
dupont's Avatar
yea its working, when i get stuck one front tire spins the other stops because of the limited slip. maybe I need new tires
Old Feb 5, 2010 | 10:06 PM
yeah my tires made a huge difference, sometimes i cant go ahead anymore but i put it in reverse and rock the 4wheeler back and forth and it backs right up without much trouble
Old Feb 5, 2010 | 10:15 PM
dupont's Avatar
same here I guess its because the reverse is geared lower. Thanks for all of your input
Old Feb 5, 2010 | 10:17 PM
not a problem, wish i could be of more help but this is my first 4wheeler, im a jeep guy so this is all new to me
