Kodiak question
Old Feb 8, 2010 | 01:48 PM
dupont's Avatar
Default Kodiak question
I have a 1998 kodiak. when it gets stuck (witch is alot) only the front left tire and the rear right tire spins. I know it is limited-slip but is this how its suppost to work?
Old Feb 8, 2010 | 10:33 PM
KNOWSALOT's Avatar
The Facility
The front end seems to be working fine. The side that loses traction is the one that will spin on that model. (Great engineering huh?)
As for the rear, it's a solid rear axle and wouldn't be spinning only the right rear wheel unless the left wheel wheel hub has stripped splines.
A very easy and cheap fix....so long as it hasn't went on for so long that now your axle splines are worn to. But mostly it's just the hub,..it's made of a softer metal than the axle.
Old Feb 10, 2010 | 10:44 PM
dupont's Avatar
thanks alot man. the front is just stupid but i thought the back was the same. you were right so i need a new rear hub which i can get for pretty cheap.
Old Feb 11, 2010 | 06:13 PM
jleo's Avatar
Its just like a car, The reason only one tire spins in the front when your stuck is for turning. It would be extremely difficult to turn while riding in 4wd, if the power was applied to both front tires at the time.
Thats why some newer quads have selectable front diff. lock. That way when can turn the front diff. lock on when you need it.
Old Feb 15, 2010 | 09:41 PM
dupont's Avatar
I just ordered the new hub I really appreciate the help.
Old Feb 16, 2010 | 04:06 PM
dupont's Avatar
do you think it wont get stuck so much now?
Old Feb 24, 2010 | 04:25 PM
dupont's Avatar
I ordered it off of ebay it cost $22 altogether. It came on moday put it on and now its a tank. I was just going threw 1 foot of snow like it was nothing. Again I really appresiate the help.
Old Feb 28, 2010 | 12:26 PM
sallyport's Avatar
a little trick is hold the front brake alittle in 4x4, will sometimes lock both tires....
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
