warrior HELP!!!!!!!!!!!!!!
Old Feb 18, 2010 | 06:56 PM
jcole11's Avatar
Exclamation warrior HELP!!!!!!!!!!!!!!
my 1996 warrior wont start i checked ever thing and the orange wire from the coil is not getting power were does it run to it will crank no power to the coil any idea thanks
Old Feb 18, 2010 | 09:13 PM
Kevin R.'s Avatar
Most likey a pick up coil and/or stator. you need to do a ohm(resistance) check on the pick up coil leads. Go to rickystator's web page for the wiring chart and ohm amounts. The cdi box's hardly ever go out.
Old Feb 18, 2010 | 09:17 PM
jcole11's Avatar
i checked the ohms thur the orange wire and it was good
Old Feb 18, 2010 | 09:22 PM
Kevin R.'s Avatar
The stator is a 3 wire plug under the gas tank. The plug comes up from the side cover on the clutch lever side of the bike. The orange wire is not pluged up to the stator, just the cdi box. On my '97 its a green, brown, and red wire at one plug, 3 white wires to the voltage reg, and a green and black wire on the 3rd plug. That just means your coil lead at the cdi is good.
Old Feb 18, 2010 | 09:24 PM
jcole11's Avatar
so i should check that plug
Old Feb 18, 2010 | 09:30 PM
Kevin R.'s Avatar
Yup.
Ricky Stator - Manufacturer of ATV & Dirt Bike Stators, Electrical Components, Lighting Systems and Suspension Products
Go here and look up the plug and wire code for part number RS200W6
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
