Warrior 350 suspension mods
We all know the warrior has a terrible suspension in stock form and I am looking to upgrade my 92. Someone was telling me to run banshee front shocks and a raptor rear shock, has anyone ever heard of this or could they shed some light on this? Does anyone have any other ideas?
banshee shocks are a direct replacement and a little bit better then the warriors shocks, the only problem you will find is the rear banshee shock will rub against the airbox a little bit but thats an easy fix,you can also run raptor shocks and i believe yfz shocks but you gotta be carefull with using them, they make the warriors stance alot different, i cant remember the whole story on running those on a warrior but theres something to it, Works also makes some decent shocks for warriors that arent to pricey, specially if you ebay some used ones off a warrior/banshee.
The Raptor 660 rear shocks will bolt right up but are a lot longer, which makes the ride height taller and the ride more stiff. I don't think the YFZ450 rear shocks will bolt up without a lot of modification. The 450 shocks have a different mount on the bottom. Just replacing the front shocks will be a major improvement.
the banshee front shocks made a little difference but still way better than stock. the banshee rear is great and so is the rappy 660 rear. bigger guys tend to like the rappy since it raises up the rear a bit. yfz shocks are best but you'll need to fab new lower shock mounts. im trying to design +2 or 3 long travel a arms to accept these shocks
09-23-2015 06:23 AM
