Grizzly 700 opinions
Old May 10, 2010 | 10:31 PM
bassman512's Avatar
Default Grizzly 700 opinions
Hey guys new here. Im buying a grizzly 700 in a few months, and had some questions and looking for some criticism. Looking at ss108 on 26" zillas(knowing they actually measure 27"). Any opinions on this configuration. I ride alot of 70% trail and 30% everything else, but wanna know that when i get to a deep mudhole im gonna go through it no problem. Also will i need a clutch kit? Will i lose any power or speed with this setup? Any input will be greatly appreciated. Thx.
Old May 13, 2010 | 11:41 AM
countryboy8602's Avatar
Am looking into the same size zillas myself, only with ss212's. I've heard the zillas actually measure smaller on average so you may want to go with a 27"? I'm fine with the 26" as I don't want to stray too much from stock size. They look to be one of the best all around tires out there, with an affinity for the mud should you go there. They're quite light in comparison to most and I wouldn't think you'd notice a power difference from stock, therefore a clutch kit shouldn't be necessary.
Old May 13, 2010 | 11:58 AM
DODGE57HEMI's Avatar
Mopar Man!
As long as you dont go to 28's you will be fine without a clutch kit. With that said a clutch kit with or without big tire help out tremendously!
Old May 14, 2010 | 10:58 AM
Do you run a clutch kit Dodge? Was wondering what some of the more popular brands might be.... a little extra low end tire spinning grunt (even without bigger tires) would't be bad thing!
Old May 14, 2010 | 11:13 AM
Mopar Man!
Kinda my dealer dyno'd and clutched my machine to run at top performance for the altitude we have here in Co. I am not sure what brand they used tho!
Old May 14, 2010 | 11:18 AM
tramp's Avatar
700 has way enough power for 26" or 27". Only time you may need a clutch kit is if you plan to ride at altitude. 5000' and above. When going up in altitude you need to stiff'en the spring and light'en the fly-weights (basiclly what you are doing with a clutch kit). This allows for a higher rpm before engagement and maintains the rpm thru the power curve. The reason is the higher in elevation you go the more Hp you loose. Upto as much as 30-40% depending on elevation climb.
Old May 19, 2010 | 12:27 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Hmmm, you needed to tune the carb with EFI? As for tires, I am a little out of my element on that one. I have used stock tires forever. I have seen guys get those real big monsters and well, if you spend a great deal of time in the mud, I guess you could use them, but I don't. I go around mud if I can. (I hate to wash mud off me and the machine) I have heard because of the sidewall stiffness, they can give you a fairly bumpy ride. They will not work in rocks. No personal experience though, so take it for what it is worth. I prefer to put my money into a good winch. The winch works every time... something that the tires may not.
Pgbama11
Jan 16, 2016 08:19 AM
Robinhood
Dec 26, 2015 10:28 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
