piston removal on a warrior 350
have the bike at TDC remove timing chain tensioner then take the cam sprocket off, take some wire or a clothes hanger and rig it to the handle bar or something to hold tension on the chain so it wont fall while your doing other things then the head will pull off then take the jug off, stuff the area around the piston/rod with rags or something that way nothing can fall into the crankcase while you take the piston off the rod, take the wristpins out and then the rod pin will slide out and piston will be free.
