05 660 Raptor exhaust problem, running hot
Old May 15, 2010 | 01:49 PM
cody.turnbull's Avatar
Default 05 660 Raptor exhaust problem, running hot
My 660 raptor exhaust gets so hot the pipes are glowing red. Any ideas?
Old May 18, 2010 | 10:50 PM
tfunk22008's Avatar
well first of all have you done any motor work? if the bike has a high compression piston and your running pump gas that would cause preignition and it would run hot. Also check the coolant level in the radiator and the resivoir make sure both are at appropriate levels... does the raptor have stock exhaust or is it aftermarket. another cause is the bike could be running lean which causes higher combustion temperatures due to the longer it takes the fuel to burn start there
Old Jun 10, 2010 | 12:09 AM
dirtjunkie's Avatar
you are running lean, raise your needles up 1 or 2 places & run bigger pilot jet
Hankey Pankey
26
Oct 18, 2020 03:50 PM
alex_2011
Jun 9, 2015 10:12 AM
blaze_master
May 26, 2015 11:18 AM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
