2009 Yamaha Wolverine - Engine is badly bogging down when giving it throttle
Old Jun 8, 2010 | 05:11 PM
travlemon's Avatar
Default 2009 Yamaha Wolverine - Engine is badly bogging down when giving it throttle
Hey everybody,
About my machine:
I've got a 2009 Yamaha Wolverine 450 ATV. Everything on the quad is stock, nothing has been tampered with or modified.
The problem: I thought I was losing my mind the past few times I have ridden this thing. I would be doing about 20mph or so on a trail, and I could have sworn it felt like it was bogging down when I gave it gas to speed up.
It happened again the next time I took it out, and more noticeably. I stopped and shut it off for about 20 minutes. When I started it back up, it didn't SEEM like it was doing it again. However, a few minutes into the ride back home, it was bogging much more.
Now, I can't even ride it. When I start it up, it sounds fine. Listening to it idle, or driving it at a very slow backyard speed, I'd never know there's a problem. Once I nail the throttle to start going fast, it bogs down terribly, but never shuts off.
The best way I can try to describe how it bogs down is that it sounds like like there's a computer limiter that just won't let it rev up to a certain RPM.
Speculation: My impression is that it may be something computer related of some sort. Not something mechanical with the engine itself.
Can anyone point me in the right direction as to what parts I should check out or what I should look for?
Any help is much appreciated, thanks so much!
Old Jun 11, 2010 | 08:37 PM
2wolvies's Avatar
you most likely have some thing in your carb. that blocks the flow .
take the bottom off of the carburator and clean it out
Old Jun 11, 2010 | 09:14 PM
travlemon's Avatar
awesome! thank you for the response! i just really wasn't sure where to begin. now i have a starting point! i'll get to it, and post back here with the result!
Old Jun 12, 2010 | 10:56 AM
HeftyLefty's Avatar
Check the vent tubes for tank and carb for obstructions, too.
Old Jun 12, 2010 | 07:49 PM
95wolv's Avatar
I know the older Wolverines and Warriors had a problem with the parking brake switch going bad, it would keep the rpms from building so you didnt burn up the rear rotor driving with the parking brake on, my 95 Wolv did not have this, and burnt up a caliper and warped a rotor doing it !!. Check by the brake lever on the left side, see if there are 2 small wires coming from brake handle assembly. Follow them down, see if you find a plug, if so, unplug it and see if it runs any better. Im not sure if the wires need to be shorted or open to keep the reve limiter from kicking in, been years since I read up on this problem. But the primary symptom of bad parking brake switch was good idle, then falling flat on its face when you try to rev it up and move.
Old Jul 31, 2010 | 04:57 PM
travlemon's Avatar
thanks 2wolvies! you were absolutely right. I opened up the carb with someone who knows what they're doing, and there was a small piece of some type of debris or dirt. cleaned it out with carb cleaner, re-assembled everything and it runs fine now.
thanks again everyone!
tylerhenson25
Ask the Editor
May 11, 2017 07:04 AM
holmbergm97
May 27, 2015 07:23 AM
ATV4ME
Jun 28, 2000 12:45 AM
Rob
Sep 28, 1999 07:21 PM
Tornado
Aug 1, 1999 12:08 AM
