Water possibly in the engine?
Old Jul 15, 2010 | 08:38 PM
GrungeGod494's Avatar
Default Water possibly in the engine?
I have a 02 Blaster (stock) and I've had no problems since I bought it 9 days ago, but after washing it 3 days ago, and letting it sit since I had work, It's been running weird. I took it for a ride, and when i pulled the clutch in to put it into neutral and it stalled, after it stalled, i touched the engine and it was hot to the touch, yet it still took 5 good kicks to get it started, and the idling is very weak unless i rev the engine, and when i add barely any throttle, it shuts down. I took the seat, and the airbox cover off thinking the filter was wet, but it's dry, but i heard like a...gurgling/sucking sound from the airbox when i took the filter off. It will idle fine for about 3 minutes, then just stall.Also I noticed its smoking A LOT more than usual, so I shook the gas up in the tank, and it still smokes. (My blaster is self mixing and I left the gas on while it was sitting) But I started it up yesterday, and it was running fine. Throttle response was crisp and clean.
Old Jul 15, 2010 | 10:39 PM
draarong2004's Avatar
i'm assuming electrical, it could be the nuetral sensor wire is loose/corroded and maybe washing it knocked it around to the point its barely touching right now, i'd suggest getting a repair manual to find out what wire it is(and this book will help with future problems as well). but it seems electrical to me.
Old Jul 17, 2010 | 01:45 AM
its running fine today.
Old Jul 17, 2010 | 06:57 AM
HeftyLefty's Avatar
Probably wet wiring connections. Check battery cables, too. Could be loose.
Nondem
Feb 22, 2020 12:20 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
