is this running to lean?
Old Aug 5, 2010 | 03:29 PM
benks's Avatar
Default is this running to lean?
i put an exhaust, intake and bigger main jet (came with exhuast)on my 07 wolverine, and set the mixture screw 2 turns out, ran like crap, turned the screw 3 turns out, and it still runs like crap, takes about 5 seconds to rev up to full throttle, cant hold an idle, and backfires on deceleration, sounds like its lean to me, but my question is, is it ok to turn the mixture screw out 4 or even 5 times? or do i need to pony up and buy some even bigger jets?
Old Aug 5, 2010 | 07:46 PM
sdm111's Avatar
2 strokes or 4
If I were you, I would go one bigger on the pilot jet and see what it does. The main jets that come with exhaust aren't always the best setup. Altitude, riding style, climate, and just that particulat bike in general may require a bigger or smaller jet. The backfiring on decel. can be a sign of an exhaust leak or running lean. How much bigger that stock is the main jet? Also the addition of an aftermarket intake, or taking the airbox lid off will alter the jetting also. On one of my bikes when I installed an aftermarket exhaust and no airbox lid the manufacturer reccommended going up one size on the main and after tuning it in I ended up 7 sizes up.
Old Aug 7, 2010 | 11:15 PM
benks's Avatar
wow 7 sizes up? guess ill get that dynojet kit
Old Aug 11, 2010 | 11:22 AM
318motorsports.com's Avatar
Ive got DG exhaust kid on my 92 timberwolf and have it at appropriate settings, factory jet kit. when i let off the gas it likes to pop kinda like a 4 wheel drive chevy with big pipes... that mean i need to turn out the mixture screw a little more? or should i just get jet kit and be done?
Old Aug 11, 2010 | 04:07 PM
sdm111's Avatar
2 strokes or 4
When you let off the throttle and it pops you're either lean or sucking air at the headpipe to cylinder gasket. The mixture screw probably won't help it's only for the pilot jet.
Old Aug 16, 2010 | 04:52 PM
cool. i'll double check the exhaust bolt studs and make sure its sealed.
Old Aug 16, 2010 | 07:49 PM
benks's Avatar
man i put off the jet kit too figuring i could go without it after my intake/exhaust, man was i wrong, get it now and be done with it lol
Frisky2050
Apr 9, 2020 11:19 AM
marioi911
Sport Quads
Jun 30, 2015 12:00 PM
Mphillips
Jun 26, 2015 03:52 PM
hoopduerr
Jun 10, 2015 03:00 PM
dano00
8
Dec 27, 2000 10:10 PM
