Warrior Won't Start
Old Aug 26, 2010 | 10:18 PM
  #21
andyhig's Avatar
Well need to find a CDI for an '89 Warrior. If anyone knows where I can find one I would appreciate. Very hard to find for this year.
Old Aug 27, 2010 | 12:17 AM
  #22
dirtydave4's Avatar
try www.mrcycles.com , they will have one but 500 dollars
Old Aug 28, 2010 | 12:39 AM
  #23
andyhig's Avatar
Well I put a Craig's List add out in my area and found someone local with one. Even said he will give me my money back if it doesn't work. Good thing is if it doesn't work I have someone who can get me one for 10% over the dealer's cost so I won't have to pay the $500 for one.
Old Aug 28, 2010 | 02:54 PM
  #24
andyhig's Avatar
Got a new CDI and still nothing. I have a wire for the lever switch just dangling and usually connect it to a ground when I try to start it. Where does this need connected to and does grounding it help it any?
Old Aug 28, 2010 | 10:29 PM
  #25
madmantrapper's Avatar
Originally Posted by andyhig
Put a new starter in now it cranks fine. Now getting an inconsistent spark. It will fire every 5 cranks or so. Person who owned it before did jump it from a car to crank it. I'm thinking maybe a bad ignition coil. Not too sure on this one.
What do you mean here? It will have spark every five revolutions of the crank or every fifth time you try to start it? Check spark with the plug removed.
Old Sep 1, 2010 | 09:34 AM
  #26
andyhig's Avatar
I take the spark plug out and set it on the head. That's how I always check for spark on it.
Old Sep 1, 2010 | 04:33 PM
  #27
dirtjunkie's Avatar
if its making a spark its not the coil, might be the pickup coil near the stator, but not the ignition coil...
edit : look over at http://www.yfm350.com/forums/forumdisplay.php?f=58
Old Oct 6, 2010 | 02:14 PM
  #28
andyhig's Avatar
Been a while since I updated on this, but I have finally found time to start playing with it again. Here's where I'm at:
Parts replaced:
Ignition coil
CDI
Starter
Main Switch
Starter Solenoid
Tested the pickup coil resistance and it's right in spec. I've ran the test on the stator about 20 times and everything still checks out fine but yet I still don't have spark. I went over all the wiring and hooked all the switches up to where they need to be. I cleaned all of the contacts in the start button. Still don't have any spark.
Old Oct 7, 2010 | 07:45 AM
  #29
HeftyLefty's Avatar
replace spark plug wire.
Old Feb 11, 2011 | 07:14 AM
  #30
sipes40's Avatar
Did you ever get this problem fixed? My 87 warrior is doing the same thing. I was riding when it started breaking up realy bad and then shut off with no spark all with in mins. Took home started messing with it was making a god awful sound in the side case, pulled cover off, found that the 3 stator bolts had worked loose and stator started flip flopping around in the flywheel. Got new stator for 87, installed, now only get a spark after holding down the start button and engine is cranking over for a split second when I release the start button I will get a single spark.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
